Thread: When to add more DE to sand filter
    Attleboro, MA.
    Default When to add more DE to sand filter
    I was thinking of adding some DE to my sand filter. I've read posts on this forum regarding this and think I have it figured out when to add and how much to add. Basically 1/3-1 cup depending on when the filter's psi goes up 1lb.
    My question is when to add more DE to the filter...is that just after I backwash?
    I have some really fine "something" at the bottom of the pool. I had a sand problem last year with the filter putting sand into the pool. I fixed that problem and then it looked as if it was doing it again. So for 2 days I had some panty hose on the return and there wasn't a grain of sand in it. So either it's really fine dust that the filter can seem to filter or dirt/pollen from the lawn/trees.
    I have used a sock on the skimmer basket but it was so nasty everyday to clean out so I took it off. Do you think the filter sock would make a difference?
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: When to add more DE to sand filter
    Yes, add more DE after each backwash.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
  1. How often shoud I replace sand in sand filter?
    By mikef in forum Pool Equipment & Operations
    Last Post: 07-18-2011, 11:41 PM
  2. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  3. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  4. Sand in bottom of pool from sand filter
    Last Post: 06-20-2006, 01:01 PM
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
