Thread: Chlorine pucks
    Whitby, Ontario, Canada
    Default Chlorine pucks
    I hear all this talk about not using chlorine pucks as it will continue to raise your CYA values. Can you not purchase pucks without CYA in them, that won't cause this to happen ?
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Default Re: Chlorine pucks
    Not anymore (none that anyone on here's been able to find anyway)...a few years ago you used to be able to get the non-stabilized pucks, but the "big" manufacturers quit making them in leu of the more expensive (bigger profit margin) stabilized pucks that they can sell for more.
    Sherra
    Kershaw County South Carolina
    18x34 IG 2' radius rectangle vinyl liner (approx 27,500 gal) 1 1/2" pipes installed March 2006
    (previous AG pool owner)
    It's not that they've quit making them in lieu of the more expensive pucks--the other type of puck was a different chemical--calcium hypochlorite--and the manufacturers changed the packaging to a puck without a plastic capsule, which dissolves into mush pretty quickly. The trichlor pucks are the ones that are stabilized, and the stabilizer is what keeps them from getting mushy like the other type.
    You can still get both types, but you cannot use the cal hypo puck in an inline feeder.
    Can you use a cal hypo puck in an offline feeder ?
    My understanding is that when the chemical pucks get wet, they put off varying degrees of heat and gasses, and the reason you can't put cal=hypo in a feeder that's not designed for it is that the trichlor feeders aren't equipped to handle the heat and pressure buildup of dissolving cal-hypo. So the short answer to your question is, no, don't put cal-hypo pucks in a feeder unless it's specifically designed for cal-hypo.
    Just found the HTH Duration (cal-hypo) "capsules" on this web site (I get their "sale" e-mails, but never buy anything from them).
    http://www.poolsupplies.com/Product_...neTablets.html
    Sherra
    Downingtown, PA
    From site:
    Lasts for days! Perfect for pool owners with busy schedules or those long Summer vacations. Put duration in your skimmer. Each tablet is specially wrapped in plastic to eliminate any need to touch the chlorination. Can't overstabilize your pool. Composed of calcium hypochlorite.
    Note: DO NOT place in a chlorinator !!
    You may receive six 3.94 lb containers instead of one pail.
    Item No. Size WAS NOW
    148270 3.94 Lb. $29.99 $14.99
    148275 23.5 Lb. Pail $69.99 $49.99
    One 10.5 oz. capsule treats 10,000 gallons of water and lasts 5-7 days!
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    48 Sq Ft Hayward D.E. Filter (2003)
    1.5 hp Hayward Super Pump (2006)
  1. 99% Chlorine Pucks
    By singinginmycar in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2010, 05:00 PM
  2. Bleach vs pucks effective chlorine.......
    By chrisexv6 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-09-2008, 03:06 PM
  3. NuWater Chlorine Feeder and Pucks
    By psciotti in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-04-2007, 09:16 AM
  4. Chlorine Pucks
    By donfranko in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-25-2007, 12:04 PM
  5. Chlorine Pucks vs Bleach
    By jimgregory in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-10-2006, 07:45 AM
