Results 1 to 4 of 4
Thread: ChlorEase
    Jacksonville, Fl
    Default ChlorEase
    Hello! We purchased a ChlorEase SWC for ourbrand new above ground pool. Our pool was installed yesterday and is filling up as I type! I have a question for those of you who use ChlorEase.
    How well does it work?
    And have you had any problems with it?
    AND this may seem like a really silly question but can it shock you? Since it's plugged into an outlet and all?
    Tricia
    24' Artesian Echo Canyan Above Ground Pool
    Nature2 Express
    ChlorEase
    PatL34 is offline Lifetime Member Widget Weaver PatL34 2 stars PatL34 2 stars
    Saint Cloud, FL
    Default Re: ChlorEase
    Did you check the warranties from the pool and SWCG manufacturers regarding the use of a SWCG in an AG pool? You might want to do so for peace of mind, as some AG pool and SWCG frown on this combo.
    So long as the outlet is GFCI protected, there should be no problem.
    Hope this helps.
    Pat
    20,000 Gallon IG Diamond Brite pool, 1.5 HP Sta-Rite pump, Hayward Microclear DE3600 filter, Favco solar panels, Poolpilot DIG-220 with SC-48 cell.
    + SWCG OPERATION thread here: http://www.poolforum.com/pf2/showthread.php?t=1226
    + SWCG Running Costs post here: http://www.poolforum.com/pf2/showthread.php?t=316
    + Effective Stabilizer addition post here: http://www.poolforum.com/pf2/showthread.php?p=6645
    Jacksonville, Fl
    Yes, we asked beofre we bought the pool if we could use a SWG and they said yes. They said the only thing that ruins the warranty on the pool is using liquid chlorine. I wondered if that sounded right though...? Doesn't the salt turn to chlorine?
    Saint Cloud, FL
    That does not make sense. Liquid chlorine is bleach, usually 6%. They may be thinking of liquid chlorine bought from a pool store, which can be as high as 12% sodium hypochlorite.
    The salt is converted to chlorine, and is replaced with muriatic acid, not salt.
    You might want to check with the Chlorease manufacturer as well for the warranty in using their unit in an AG pool.
    Hope this helps.
    Pat
  1. Chlorease / Smartpool SWCG problems
    By jcar27 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-27-2012, 11:28 AM
  2. Anyone familuar with Chlorease?
    By bssage in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-22-2012, 12:09 AM
  3. Has anyone tried this CHLOREASE
    By slowtan in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-02-2007, 09:32 PM
  4. Chlorease help
    By Tattoomom in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-29-2006, 02:31 PM
  5. Has anyone tried this CHLOREASE
    By slowtan in forum Pool Equipment & Operations
    Last Post: 03-30-2006, 07:16 PM
