The method I use to backwash is run in backwash until clear, then filter for about 2 minutes, then backwash again until clear, filter one more time, and backwash once more until clear.
This "bumping" feature helps to dislodge as much of the old stuff as possible.
The DE48 should require about 6 lbs of DE only and should not be exceeded, otherwise you will be back washing more than you need. It should say on the side of the filter how much to add, or check with the manufacturer's web site.
Hope this helps.
Pat
