Results 1 to 4 of 4
Thread: Re: tiny bubbles
    New Jersey
    Default Re: tiny bubbles
    I do not have a test kit but I am using the test strips and according to them all the test results are all normal. I shocked the pool 2 weeks ago after a party and again last night after a rain storm. I also added baking soda last week due to low alkalinity. I also added algecide last week, for the first time.
    Other than the foamy bubbles everything seems fine.
    Do I need to buy a test kit and can you recommend one.
    Sanford, FL
    Yes you need a test kit - a 5-way DROPS based test kit is usually available at Wal-Mart. Taylor's makes a good kit and Ben's kit (available on www.poolsolutions.com).
    You will need to post your chlorine level, PH, ALK, CA, and CYA. You can probably take a sample to your pool store for results today- but don't buy anything. Just post your numbers and get a good test kit.
    Welcome to the forum - this place has a lot of very good information .
    Completed 8/21/06
    14,000 gallon 3'-6' concrete pool with Diamond Brite
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Hayward Super II Pump - Cartridge filter
    See pictures here http://www.philsimmons.com/family/ga...mages&keyword=
    Your bubbles are almost certainly from the algaecide. And yes, add another vote for the test kit--get a good, drop-based kit, it will pay for itself over and over again.
    Kentucky
    Certianly get a drop based kit...
    Ben's is great (I bought mine last year) but the Wal-Mart 5 way will do the trick, but only has 2 CYA (Stabilizer) tests in it - probably sufficient for one season really.
    I also agree that the bubbles are likely from the algecide. If you are keeping your water properly balanced you won't need very much (if any at all) algecide. I usually have to add a quart mid summer to fight of a little persistent algae, but that's about all. Only use the 60% Polyquat type algecide - stay away from anything else.
    By the way - the strips are notorious for giving spotty test results at best.
  1. Tiny micro bubbles coming from returns
    By krdowns in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-16-2013, 11:16 PM
  2. tiny leaf particles in pool
    By ronrobyn111 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-06-2011, 02:43 PM
  3. Yuck! Tiny bugs all over the outside of our pool
    By blessedbeingmom in forum Pools, Pets and Creepy Critters
    Last Post: 07-03-2010, 12:24 AM
  4. Tiny Bubbles
    By rickw in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2006, 11:31 PM
  5. What are teses tiny rust-like stains?
    By poolbee in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-13-2006, 07:56 PM
