Closed Thread
Results 1 to 9 of 9
Thread: Kiddie pool leak
    Honesdale PA
    Default Re: Kiddie pool leak
    Silicone seal can be a good temporary seal even underwater if you squish enough of the stuff into the leaking area. Did a temporary patch a few years ago when I punched a hole in my skimmer housing....stupid bubu. In an application like yours I wouldn't rely on silicone seal.
    Again thank you for the replies. Looking into this material I think I may have found a sealer. 3M makes a marine adhesive sealant 4200/5200 fast cure that seems to be right up my alley. I will be visting a marine store this weekend and will let you guys know how I made out. Again thank you for the replies and any other ideas are greatly appreciated.
    Well, just an update the 3M Marine sealant 5200 did the trick.
Closed Thread
  1. Kiddie Pool Chemicals
    By ercvt in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2013, 02:45 PM
  2. Kiddie pool PH help
    By landbk in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-27-2012, 10:42 AM
  3. New small kiddie pool.
    By chadgreen in forum Above-Ground Pool Construction & Repair
    Last Post: 07-28-2011, 11:54 PM
  4. kiddie pool
    By jnkoh in forum Above-Ground Pool Construction & Repair
    Last Post: 06-30-2011, 07:20 AM
