Thread: New Testkit & My Results
    Richmond, IN
    Default New Testkit & My Results
    Hello,
    Here are my results-
    FC: 24
    CC: 0
    TC: 24
    pH: 7.2
    Alk: 110
    Cal: 300
    Cya: 65
    Its a 45,000 gal. plaster in-ground pool. The water is very clear. I'm a little concerned with the high chlorine reading, though.
    I have a "puck chlorinator," but have removed the pucks 2 days ago, as I plan to use only bleach now that I have my new PS234 testkit.
    Any advice/comments would be great.
    Thanks,
    Paul
    duraleigh Guest
    Default Re: New Testkit & My Results
    Quote Originally Posted by psbailey
    Hello,
    FC: 24
    CC: 0
    TC: 24
    pH: 7.2
    Alk: 110
    Cal: 300
    Cya: 65
    Thanks,
    Paul
    Hi, Paul,
    Those are good numbers. Nice work. I would let the Cl drift down and maintain it around 5-10ppm with your current CYA level. It's not at any danger level currently....it'll probably come down 2-4ppm daily on it's own
    Good thinking........ditching the pucks.
    Clear water and the test kit in your possession to help keep it there.....life is good!
    duraleigh Guest
    Hi, Paul,
    Those are good numbers all around. Nice work. I would let the Cl drift down and maintain it around 5-10ppm with your current CYA level. It's not at any danger level currently....it'll probably come down 2-4ppm daily on it's own
  1. Got my new K-2006 testkit...now what?
    By pmoneykitty in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 07:19 PM
  2. Testing high chlorine levels (without a good testkit)
    By Watermom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2010, 01:52 PM
  3. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
