Results 1 to 9 of 9
Thread: Got my kit, here are my results
    Peoria, AZ
    Default Got my kit, here are my results
    I was very excited to get my kit. I ran my first test yesterday and found that my tap water had more chlorine. The salt cell was totally gummed up. I disolved the calcium using diluted muriatic and added 2 gallons of pool store chlorine. 24 hours later I got the following results.
    FC: 2.5
    CC: 0.5
    TC: 3.0
    pH: 7.8
    Alk: 160
    Cal: 1000+
    Cya: 90
    I have a 17000 gal Pebble Tec pool with a Pool Cubby SWG. What's next?
    duraleigh Guest
    Default Re: Got my kit, here are my results
    How does your water look?
    Secondly, it appears you have a serious calcium issue. 200-400 would be the range to shoot for and, assuming your test results are correct, you are more than double that. That would explain your salt cell calcifying as well.
    Confirm that you are comfortable with the test results for Ca and we'll help you figure a plan to get it down.
    How long did it take to get your kit?
    Peoria, AZ
    Quote Originally Posted by duraleigh
    The water is mostly clear. The guess strip indicated a hardness at 1000ppm. I stopped doing the test from the PS234 after I got to 50 drops. I figured that I did something wrong and didn't want to waste any more. I'll do the Ca test again with the PS234 and report back.
    Peoria, AZ
    Quote Originally Posted by Mr Bill
    I pre-ordered on 5/6 with FedEx Ground. It left Chattanooga,TN on 6/13, and arrived in Peoria, AZ on 6/16.
    Peoria, AZ
    I retested my Ca and at 125 drops I decided that it was time to stop wasting the Ca #3. For grins, I transferred some of the fluid from the test, into one of the small vials and added some more #3 and it turned a nice blue quickly. If I were to make a guess, my pool is floating around the 2000 - 2500ppm Ca level. Don't know if it's important, but I live in Arizona and we're known to have hard water. Thank you in advance for your help!
    Sanford, FL
    Have you tested your fill water for CA?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    duraleigh Guest
    Redael,
    That calcium level is gonna' be problematic. I have no personal experience but, if it were my pool, I'd work on lowering it. The two possibilities I see mentioned on this forum are 1)partial drain and refill if your fill water is acceptable and 2) use of a water softener to remove the calcium.
    Since it appears to be a regional problem, local pool companies may be able to give you some assistance based on their experience.
    Peoria, AZ
    Quote Originally Posted by Simmons99
    Sorry it took so long to get back to the forum. I just tested my fill water for CA and it is 190ppm.
    I'm thinking about going the drain route. What do you all think?
    -sdw
  1. first results, please help
    By vinouspleasure in forum DPD-FAS based testing
    Last Post: 06-13-2010, 02:42 PM
  2. More 234 results
    By drband in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2006, 02:49 PM
  3. Pool store results vs my ps223 results!
    By scarywoody in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-20-2006, 06:47 PM
  4. First 234s test results and warning about pool stores' results
    By SoCalBoo in forum DPD-FAS based testing
    Last Post: 06-16-2006, 02:48 PM
  5. First set of results
    By maker in forum DPD-FAS based testing
    Last Post: 05-25-2006, 09:48 PM
