Results 1 to 5 of 5
Thread: The blues
    JohnnyP is offline ** No working email address ** JohnnyP 0
    Unhappy The blues
    First of all I want to thank everyone that answers these posts.It is appreaciated.Now for my problem.Have opened my pool 21 foot 9500 gallons.Testing is giving me the blues.I can not get a reading for the chlorine test.I have put 2 gallons of bleach in so far and 1 floating 3 inch chlorine puck.The water seems like it is turning a faint green color.Will that get my reading up so I can get a reading to start with?Have followed some of the post and have got the PH TO 7.6(concentrating on PH was preached a time or two).It was reading awful low 6.8-7.0 last night.Put a half box of BORAX in.That's the chemical problem right now.Now for the bleach calculator, how do you get a BORAX reading off of it?I am learning as I go with clorine.I was duped into using Baq for a time(5 years). I drained the pool when I closed it last fall and scrubbed and sanitized tank .Now comes the learning curve with chlorine.
    mbar's Avatar
    mbar is offline Lifetime Member Whizbang Spinner mbar 3 stars mbar 3 stars mbar 3 stars mbar 3 stars
    Ashland, PA
    Default Re: The blues
    Sounds like you have no cya. If you don't have cya (stabalizer, or conditioner) the sun will burn the chlorine right out of your pool. Without chlorine you will get algae. You will have to get your water tested and post your numbers: cl,cc,tc,ph,alk,cal,cya. If you want to take control of your own pool, invest in a good test kit. Welcome to the forum, there are lots of folks to help you here!
    Northeast PA
    16'x32' kidney 16K gal IG fiberglass pool; Bleach; Hayward 200lb sand filter; Hayward pump; 24hrs; Pf200; well; summer: none; winter: mesh; ; PF:7.5
    Joliet
    Could you post a full set of number, including CYA?
    What test kit do you use?
    thanks,
    dan
    Question Re: The blues
    I had extra Baq product so I used the return on A Taylor test kit.Can I get the IDIOTS version of pointers to use the calculator?Any cheat notes for a 9200 gallon pool for clorine,ph(BORAX,)would be nice concerning amounts needed to raise or lower ph ,chlorine levels. .I think to get off to the right foot I'll take a sample to the pool store for a water test.
    mbar's Avatar
    Ashland, PA
    On the top left corner of the bleach calc, click on more calcs, then click on settings and set it to Imperial. You will be able to see all the calculations you can do on the bleach cal in the more calcs section.
    Northeast PA
  1. I have the "pinks" (instead of the blues!).
    By onemsmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-27-2012, 03:55 PM
  2. Green pool "blues"
    By George in Georgia in forum Dealing with Algae & Slime
    Last Post: 06-30-2010, 03:51 PM
  3. New season blues
    By thewalk in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-30-2007, 04:52 PM
  4. Hayward Navigator tangled up in blues ....
    By PoolFool123 in forum Pool Cleaning: Manual or Automatic
    Last Post: 09-01-2006, 01:54 PM
