I would do a water pressure test instead of an air test. Plug one end of the pipe. For the other end use PVC adapters down to a 3/4 " hose adapter. Use your garden hose to pressurize and fill the pipes. You might want to plumb in a pressure gauge as well. All the parts can be found at your local Home Depot PVC section and drip irrigation section.
