Results 11 to 20 of 28
Thread: Is there a certain window of time
    IL.
    Default Re: Is there a certain window of time
    After monkeying with this all weekend, I have come to the following conclusion-
    Aerating WHILE adding acid to lower PH is counter-productive.
    I added more acid to get to 7 (actually just a hair below), waited until I got there then fired up the sump pump aerater. The next morning the PH was still 7, so I did a bunch of cannon balls and general splashing about, then left the aerater running while we were out of town. When we got back, PH was back up to 2, so I stopped all aeration and added acid to knock it back down. Started aeration and did a bunch more manual aeration, then checked PH again before bed, it was up to 7.3. Stopped aeration, added acid and went to bed.
    Continued this process through Sunday. Got the alk down to 150, this morning PH was down to 7 again so I turned on the aerater again.
    In retrospect, when I was adding acid with the air leak in my return flow, it apparantly was enough to prevent the PH from dropping low enough to get carbon dioxide production, so as the PH remained stable then rose, the alk went right along with it.
    Now all I need is another gallon of acid and a few more days I have my fingers crossed I've finally figured this out.
    Tredge, what did you come up with?
    IL.
    Ben's sticky says you need to get PH low to induce carbon dioxide production.
    Once carbon dioxide is present, I assume it's no longer measurable as part of the ALK test, and this is why we get the drop, right?
    And if it's not gassed off, when PH increases due to aeration, carbon dioxide reverts back to CA, which is measurable, right?
    Anyone know at what PH level carbon dioxide re-converts to CA? Waterbear?
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    I'm letting my TA sit high. I'm pretty happy with how the pool is balancing right now and the water looks better than ever.
    If I do Aerate more out I'll probably build myself a fountain from PVC parts. Sounds like you need a Lot of aeration to make a difference in a larger pool.
    Great news on your progress!
    Some people have hobbies.....I have a pool.
    Quote Originally Posted by Rangeball
    Exactly right, except that the incease in pH is due to the CO2 being gassed off...as there is less carbonic acid the pH will rise but the buffer is in equalibrium so things shift as the pH rises..It takes a bit of time and patience to lower TA. pH determines the ratio of carbonic acid to carbonates/bicarbonates in the water.....lower pH means more carbonic acid and less measurabe TA. Higher pH is the reverse. If you remove the carbonic acid by gassing off the CO2 you have lowered the TA because you have less of the total buffer system in the water. As you you lower the carbonic acid the carbonate/bicarbonate try to reach a new equalibrim so they lower. The purpose of a buffer is to stabilze pH so the pH will rise as the equalibrium is reached. The net effect is a lower TA. In most pools the TA buffer will stabililize at a pH of around 8 so the addition of acid to keep the pH in range is still necessary.
  1. Long Time Lurker, First Time Poster
    By MikeD in forum Dealing with Algae & Slime
    Last Post: 08-04-2012, 08:26 AM
  2. still have ben's kit, time for new kit?
    By vinouspleasure in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-03-2012, 08:06 PM
  3. Long time reader, first time author
    By j_stewart89 in forum General Interest
    Last Post: 04-06-2012, 06:05 PM
  4. Maybe it's time
    By bizzelizze in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-14-2010, 08:28 AM
  5. Help! Big Time!
    By PoolKid in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-20-2006, 10:34 AM
