Results 21 to 21 of 21
Thread: CYA 230, replaced 1/2 of water...now 217???
Threaded View
    Default CYA 230, replaced 1/2 of water...now 217???
    Hi - the reason I detected the high CYA was that I was getting a rash from swimming...and so began the research and I was suspecting pseudomonas.
    I had my water tested and was told that the chlorine isn't doing anything at all being that the CYA is too high. This might explain why after shocking a month ago it took 10 days for the chlorine level to drop down to 2ppm. I should mention that my water has no odors, no cloudiness, no green tints or algae - it's crystal clear!!
    Background (before replacing water)
    - 30000 gallon plaster pool
    - Cl = 1.3ppm
    - PH = 7.6
    - Alkalinity = 160
    - CH = 530
    - CYA = 230!!!
    I then drained almost half the pool, so I'd say I replaced 12000 gallons of water. Then I shocked the pool - and took my water back to the store for testing.
    - Cl = 10ppm
    - PH = 7.7
    - Alkalinity = 100
    - CYA = 217????
    What the **** is going on here?
    For one I don't understand how the CYA could only drop 13ppm after replacing 40% of the water. For two - can someone please tell me what to do from here? The guy at the pool store said "try replacing the sand in the filter". I don't know if he was just grasping at any solution....
    Thank you,
    Matz
  1. Replaced pump
    By gohogs1 in forum Pool Equipment & Operations
    Last Post: 04-06-2012, 03:37 PM
  2. Anyone replaced AQULUMIN Nichless light
    By JJNMRSDAD in forum In-Ground Pool Construction and Repair
    Last Post: 07-30-2011, 12:06 AM
  3. How to tell if Aquarite Cell needs replaced.
    By mizzouguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-22-2010, 02:39 AM
  4. Just replaced my lightbulb
    By otitis in forum Pool Equipment & Operations
    Last Post: 07-22-2007, 11:18 PM
  5. Replaced the liner, question about the old one?
    By bkwudz in forum Above-Ground Pool Construction & Repair
    Last Post: 06-19-2007, 08:38 PM
