Thread: Solar Systems- 2" vs 1 1/2" Header?
    Poughquag, New York, USA.
    Default Re: Solar Systems- 2" vs 1 1/2" Header?
    My Solar Industries panels are 2". Their standard panels are 1 1/2". I wanted 2" because my pool was plumbed that way and we have a long way to go to the panels (130' from the pump).
    A very reputable installer I spoke with initially wanted to put in 1 1/2" ("we do all of them that way"). When I insisted on 2", he called Solar Industries and they recommended 2" for our installation. To his credit, the installer was very gracious and basically said that you learn something new every day.
    Cost was the same. I think the real difference only comes if you had enough panels to "use up" the 44gpm of 1 1/2" pipe. From what I remember, most panels can handle 4 to 10 gpm per panel (4' wide - one way, not u-turn type). So that means that if you are planning on 4 or less panels, 1 1/2" is fine, between 4 and 8 or so it is a toss up, 8 or more will really benefit from 2" pipe. (I have 8 4 x 14 panels). All of this depends on how much flow you push through the panels. The more flow (without stressing the panels), the better (see other threads on solar efficiency).
    CallMeIshmael is offline ** No working email address ** CallMeIshmael 0
    SF Area, CA
    Thanks so much for the tips!
    Peter, my case was exactly like tphaggerty's. The contractor said "Unless there's a specific need for 2", we'll be doing 1 1/2" pipe on the return end." So I was just sizing up that need. It looks like 1 1/2" should be ok, since we'll have at most 6-8 panels with good sun. 2" pipe may be overkill for our size pool/panels, but might come in handy if we choose to divert return water to a water feature (a growing interest as we re-design things!), which would also run during daylight hours.
    I think we need to take some time to digest this info here & all else we've received so far & go back to the design table for a few days. This is really helpful, so thanks for taking the time!
    SF Area, CA
    An update: We've decided to go with 2" pipes throughout, both for solar as well as suction & pressure sides. In addition, we were able to find a local seller for 2" Fafco solar panels. The contractor agrees that it might be a bit of overkill on the pipe size, but that the improved flow rates should make several aspects of the pool run more efficiently (faster turn-over, better heating, better filtering), especially with a 2-speed pump.
    Thanks again for the input!
  1. Newbie just beginning to understand "free" and "total" chlorine. . .
    By Hainsworth in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2012, 11:17 AM
  2. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  3. Changing AG pool depth from 52"-54" to 46"-48" for kids (shallow end tricks)
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 06-02-2007, 12:28 PM
  4. Great Solutions To Put "on" Solar Covers
    By tenax in forum Pool Equipment & Operations
    Last Post: 07-02-2006, 01:47 PM
  5. Esther Williams "Millenium" Pool Install "issue"
    By mrpurrhead in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 11:34 PM
