Quote Originally Posted by mas985
Sentient,
A two speed pump will nearly always save you money assuming you run the pump on low speed most of the time. If you go with the same HP pump but in two speeds, the lower speed will have about half the flow as high speed so the turnover is twice as long. This means you will have to run it twice as long on low speed than high speed for the same filtration. The power usage at low speed for some pumps is about 30% of high speed (60% reduction). But since your running the pump twice as long, you will save close to 30% of the power than high speed.
Thank you, that helps a bunch. So now I just need to pick a pump. There is a two speed version of the pump I have now, so I presume plumbing it in should be relatively straightforward, the dimensions should be identical. I think I will go ahead and do it.
I thank you all for the quick feedback and great information.
Sentient
