Thread: well water/water softener
    Default well water/water softener
    i use well water to add water to my pool. i have a water softener but when adding fill water, i use the outside spicket that is not attached to the water softener. my question is....is that okay to add water from the non-filtered spicket or should i be adding from the water that is attached to the water softener? in the past i have had iron and copper in the water. i do also use a heater for the pool. thanks
    gwrace1 is offline Registered+ Thread Analyst gwrace1 0
    Dec 2005
    South Central Texas
    Default Re: well water/water softener
    I can only tell you what I did and the results I received. We had our 26000 gallon pool installed this past March. Our water comes from and Iron rich south Texas well. I checked around for water delivery prices but no one could guarantee me that the water would be metal free. So here is what I did.
    I purchased a whole house iron filter and put it ahead of my water softener.
    I then estimated how many gallons of softened water could be created with each regeneration cycle. I used nothing but this pre-filtered softened water to fill the pool. It took many regeneration cycles over a period of 5 days to complete the fill. As a pre-caution I also treated the water with metal out and polyquat 60% algaecide. I should tell you that I'm also using a 26" sand filter with Zeolite filter medium. With pump on I let this mixture circulate for 3-4 days before turning on the SWCG. The water has been crystal clear since startup. I should also tell you that because I am running a salt water pool that I do not top it off with the softener as that changes the salt levels. I place a whole house iron filter on the end of the hose and fill from pre-softened well water. Hope that helps.
    33' Artesian Echo Canyon Ultra II round with 54" wall 26000 gallon capacity -- 1.5 HP 2 Speed Pump / Pentair 26" Sand Filter with Zeolite filter media
    Aquarite Salt Water Generator -- Complete aluminum deck with fence kit
    Aqualuminator with Fountain -- Solar Pool Lights
    Pool Pictures at the link below
    http://community.webshots.com/album/548241672nKeuyR
    yes it helps. thanks.
    also i apparently missed the post "metal control" that pooldoc responded to which answered the question also. he stated that it would help to use softened water. thanks again
    Quote Originally Posted by gwrace1
    Could you give a little more detail about the whole house iron filter?
    Brand name or a link.
    cj
    Dec 2005
    South Central Texas
    Quote Originally Posted by crackerjack
    cj
    I picked up the filter at Lowes or Home Depot. I think it was about $35-50 dollars and has the replaceable 2 micron cartridges. They advise against using this type of cartridge on a well with high metal content in the water. However I wanted to remove as many contaminants as possible even if it meant I had to go thru several cartridges to complete the fill. I think I used 3-4 for a 26000 gallon pool. I also bought a flex line installation kit for installing the filter ahead of the softener.
    I have a 2nd whole house filter that I use for the end of the fill hose. To make that work I had to buy some hose fittings for the filter. All can be purchased at Lowes or Home Depot.
  1. Would a water softener remove iron and metals?
    By whokluvr in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-22-2012, 01:01 PM
  2. got new 24x5 round intex pool need help with water. Sandy water..help
    By iwannaswim in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2011, 09:42 PM
  3. Salt from water softener.
    By dannyboy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-21-2006, 10:20 PM
  4. Considering Adding Water Softener Salt to Pool...
    By psbailey in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-03-2006, 12:31 PM
  5. Swg And Water Softener With Potassiem Chloride
    By guild1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-16-2006, 11:27 PM
