Thread: SoftSwim to Chlorine
    Question SoftSwim to Chlorine
    Feed up with SoftSwim . . . expensive and a pain. I've read much about conversions for pools with sand filters. What potential problems might I encounter with a DE filter?
    Default Re: SoftSwim to Chlorine
    HI, when I went through my conversion i also had an earth filter. I had to backwash it at least twice a day and I could not let it run overnight for the first few days as it would plug rather fast. The pressure didn't seem to go up trhat much but the amount of water flowing back into the pool was greatly reduced. I had to take the filter apart at least once a day to clean it too. It was a pain but well worth it in the end.
    Ken
    Smile Re: SoftSwim to Chlorine
    good info. better than i expected. i have to disassemble my filter regulary to clean out the earth thoroughly anyway, under the best of circumstances. thanks much!
  1. Converting from SoftSwim to Chlorine
    By Bosch232 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-19-2012, 12:30 AM
  2. What is CLC... Conversion from SoftSwim to Chlorine
    By peggles0224 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-29-2006, 09:24 AM
  3. Softswim to Chlorine Conversion ??
    By jma1_nemo in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-03-2006, 01:45 AM
  4. Softswim to Chlorine this Spring
    By tcjones in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-31-2006, 11:13 PM
  5. softswim to chlorine
    By fullhouse in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-02-2006, 11:35 AM
