Thread: Advice for Easy Set 12' x 36" pool
    Default Advice for Easy Set 12' x 36" pool
    Bought Intex 12'x36" pool. Heard that pumps dont work so well. Can anyone give me advice on buying a larger pump to work with this pool (1800 Gal), and how I should treat the pool going forward. Use duckie with Chlorine and chemicals, or use home solutions. Please advise this newbie.
    Indiana.
    Default Re: Advice for Easy Set 12' x 36" pool
    Quote Originally Posted by golfwig
    Can't advise you on the pump and filter, but they do have problems recovering from water problems. My advice is to use bleach for your chlorine source, and run the filter whenever you aren't in the pool. The filter doesn't have great circulation, so you will have a hard time maintaining a chlorine level with tablets, and if you put any powdered shock etc. in you will have a hard time filtering out the cloudiness. Be very careful about adding anything to the pool because you don't have the luxury of a big filter to clean it up.
    Quote Originally Posted by brad1974
    I'm just trying to help try simplybluepools.com This stuff works great
    Disreguard what this guy says. He has spammed another board and got kicked off and now he is trying it here under his SECOND username since he just got booted off with the username simplybluepools.com!
  1. Easy set 10' x 30"
    By Larryh86GT in forum Intex-type Pool Setup & Operations
    Last Post: 06-11-2013, 04:42 PM
  2. New Intex Easy Set 15' x 48" owner - first time pool guy
    By burmjohn in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-02-2012, 12:17 PM
  3. Upgraded Intex Easy Set pool pump and now have questions....advice please!
    By KarenG3 in forum Intex-type Pool Setup & Operations
    Last Post: 05-15-2012, 11:10 PM
  4. Advice on Metal Frame Easy-set pool?
    By tphoward26 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-03-2006, 11:26 PM
