Closed Thread
Results 1 to 5 of 5
Thread: Broken eyebolt
    Delmar, NY
    Default Broken eyebolt
    The plastic eyebolt broke off with half of the screw left in the wall anchor. This is an IG vinyl pool and the wall anchor is above the waterline. Do I have any options to repair this myself or do I need to call the pool guy?
    Thanks,
    Frank
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default Re: Broken eyebolt
    An easy-out or screw-out tool should work fine. You can get one at most hardware stores. The hard part is you need to drill into the broken bolt about a quarter to a half inch. The water level of the pool may be too high for a powered drill, so some kind of hand crank drill might be needed. Once you drill the hole, the easy-out tool should do the trick.
    beary
    MarkC is offline Registered+ Weir Watcher MarkC 1 star
    Did the screw eye break when you were trying to remove it? If it's not stuck in the threads some people heat up a flat head screwdriver really hot and press it firmly into the remaining stubb and let it cool. Now you may be able to remove the screw using the scredriver.
    Delmar, NY
    Thanks for the tips, unfortunately I was not there when the eyebolt broke off. The heated screwdriver sounds like a great idea. I'll try it this weekend, and post results.
    Delmar, NY
    Thanks again, the heated screwdriver trick worked like a charm. The only thing to remember is to cool down the screwdriver tip before attempting to remove the screw. Just dip the screwdriver tip in the pool.
Closed Thread
  1. Broken Bolts
    By planetmf in forum Pool Equipment & Operations
    Last Post: 05-29-2013, 05:11 PM
  2. Polaris 280 broken top
    By Geeper in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-06-2012, 10:16 PM
  3. Broken glass in pool
    By Redael in forum In-Ground Pool Construction and Repair
    Last Post: 12-03-2007, 04:48 PM
  4. Broken Pipes
    By mmcguire in forum In-Ground Pool Construction and Repair
    Last Post: 03-31-2007, 02:59 PM
  5. Advice: Don't fix what's not broken
    By salinda in forum Pool Equipment & Operations
    Last Post: 11-19-2006, 08:32 PM
