Thread: How long should I run my filter
    Long Island, NY
    Default Re: How long should I run my filter
    Hi John,
    from what I have been reading typically it is recommended to run it long enough to turn over the complete volume in your pool once in 24 hours - so it depends on the gpm you get from your pump.
    Patrick
    mas985's Avatar
    Pleasanton, CA
    Most pools require 1 to 2 turnovers per day. What is turnover?
    Turnover is the time it takes for the volume of the pool to run through the pump once. However, this does not mean that all of the water has gone through the pump. Some water goes through once, some twice and some not at all. To determine turnover rate:
    First, determine the head loss for your plumbing. It is usually between 45-65 feet of head. If you want a better estimate, you can use this set of formulas:
    Total Head = Suction Head + Return Head
    Suction Head = Pump Suction (in. mg.) * 1.13 (use 10' as a guess if you do not have a vacuum guage)
    Return Head = Filter PSI * 2.31
    Second, look up the the flow rate from the pump head curve that is usually in the pump manual. The vertical axis is head loss and the horizontal axis is GPM.
    Third, turnover (hrs) = Pool Volume (gallons) / (gpm * 60)
    If you can, it is usually a good idea to split the filtering time into two parts evenly distributed within a 24 hr period.
    My turnover is about 4 hours and I have solar so I run my pump 4-6 hours during the hottest part of the day to take advantage of the sun and skip the night cycle.
    Mark
  1. How long should I run my new filter?
    By G.Ritter78 in forum Intex-type Pool Setup & Operations
    Last Post: 07-08-2012, 04:38 PM
  2. How often to run various tests, and how long do you run your filter?
    By blessedbeingmom in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-03-2010, 12:29 AM
  3. How long to run filter and SWG
    By JazzMan2010 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2010, 03:11 AM
  4. How long to run filter daily?
    By famdog in forum Above-Ground Pool Construction & Repair
    Last Post: 06-06-2006, 02:01 PM
  5. How long to run filter
    By saygig in forum Pool Equipment & Operations
    Last Post: 05-23-2006, 04:45 PM
