Closed Thread
Thread: Vinyl Coping for overlap IG vinyl pool
    Default Re: Vinyl Coping for overlap IG vinyl pool
    SLS, never seen it. Can you tell me why you want to replace it with an imminent liner change? Maybe I, or someone else here can offer a solution.
    Southeast Missouri
    It's really starting to fall apart and looking bad. The sun has made it brittle. It may force me to start the remodel after the swim season this year. I was hoping to hold off until I do some remodeling inside the house.
    My liner has two bad spots in it where the previous owners let chlorine pucks set on the liner which bleached and wrinkled up the liner. I want to change out the liner before those spots fail. The liner is 8 years old but 3 years I was using Baquacil which probably was a little easier on the liner....just not on me or my pocket book...ha. I am not sure what it will do if the liner fails and I only have a sand bottom and the pool is only 8' from my house. The pool is below my basement level so I should be ok....I think unless it washes out somewhere. Where will 32,000 gallons go...straight on down?? Hopefully I never find out.
Closed Thread
  1. Replacing deck & coping on a vinyl liner pool
    By sampeterson18 in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2014, 11:22 PM
  2. Coping Identification for Inground Vinyl Liner
    By 66Corvette in forum --cleanup--
    Last Post: 06-06-2013, 11:49 PM
  3. vinyl pool / stone coping how-to help??
    By thequietwon in forum In-Ground Pool Construction and Repair
    Last Post: 03-10-2007, 06:44 PM
  4. safe depth to drain vinyl pool w/vinyl stairs
    By ScottsdaleSwim in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-13-2006, 01:47 AM
  5. wooden coping for ig vinyl pool
    By pfinnemore in forum Pool Equipment & Operations
    Last Post: 06-28-2006, 12:46 AM
