Thread: Sounds crazy but....
    Downingtown, PA
    Default Re: Sounds crazy but....
    Frequent application is the key. A family friend works in the industry has told us that most high-SPFs and water-proof versions don't protect that much better than run-of-the-mill SPF30 No Name. To really be protected you need to re-apply every 45 mins to an hour and every time you exit the pool. He used to say that the SPF was really an indicator of how long you could be in the sun before needed to apply again. I don't think any sunscreen will damage the liner in your pool, it will dirty the water and filter faster.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    haven't seen sunscreen discolor or stain a liner, what it does do is this:
    it floats on the water and eventually creates a black ring around your pool at the water line - this ring can easily be wiped off with vinyl cleaner.
  1. sounds silly but im not sure i have algae...
    By pbotz2000 in forum Dealing with Algae & Slime
    Last Post: 02-28-2012, 07:15 PM
  2. Odd sounds from my sand filter....
    By caustik in forum Pool Equipment & Operations
    Last Post: 05-14-2008, 02:36 PM
  3. Help! Crazy CYA
    By aceman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2006, 09:53 PM
  4. Haward pump sounds like air- no where to bleed
    By Madty in forum In-Ground Pool Construction and Repair
    Last Post: 07-05-2006, 10:22 AM
