Thread: What powers pressure side cleaners?
    beary is offline Registered+ Thread Analyst beary 0
    Dec 2005
    Default What powers pressure side cleaners?
    I'm wondering if I need to have my builder add anything to the pool for a pressure side pool cleaner. I don't what to leave anything option out if I can.
    Beary
    Indiana.
    Default Re: What powers pressure side cleaners?
    Higher end cleaners use a dedicated booster pump and fitting.
    Dec 2005
    So, should I have the pool plumbed with the fitting and add a booster pump later?
    Beary
    Indiana.
    Your call. Maybe research cleaners and decide what you want in the future.
    Sacramento, CA, USA.
    The important thing is to have a dedicated cleaner line installed in the pool. Make sure that it is near the middle of the pool, not an end as I have been seeing lately. After that it can be used for either suction or pressure by making a few changes at the pad.
    Downingtown, PA
    All the money dropped into a pressure side cleaner and booster pump might be better spent on a robotic. PB might not recommend because they don't 'do' anything to generate income off that.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    I agree. I am blding an inground vinyl pool and was planning on plumbing for a pressure side cleaner. After exploring all options and costs I am going with a robotic. No exta pipes, price is about the same if you have to buy the booster pump with your cleaner , robotics use less power and filter with out the pump running so again electrical is reduced. I am going to go with one of the dolphins probably from costco for $990. Chris
    Blding 18x36 IG vinyl rectangle with custom inpool steps, 22,000 gallons. Chris In Chapel Hill, NC [email protected]
