I'm no pro but think I have a pretty good handle on the blue/brown metally water. The brookwater concerns me because I don't know how to deal with Bacteria.
The first think you need to do is drop your ph to 7.2. The next thing you might try is Ascorbic Acid (Vitaman C). My water wasn't Brown it was more of a Greenish color. I used a bout 1 lb of Acorbic Acid for my 8000(+-) gal. pool. This amount may need to be adjusted based on the size of your pool.
Shut your filter down, drop the Ascorbic Acid down the sides of the pool and let it sit there for at least a 1/2 - 1 hr. Then Turn on the filter and let it run overnight. The AA will eat the chlorine up very quickly and bring it to a 0 level. This should clear up the water if it is in-fact metal. (worked for me)
After your water gets clear the next step is to prepare the water for Chlorine. I learned from this forum that Metal in water never disappears, it's sort of like living with a disease. You have to add a sequesterin agent (pool magnet, metal magic, etc) to keep the metal in what is called "in solution" this means the agent keeps the metal from reacting to chemicals (Chlorine). If the agent isn't added, the chlorine and higher PH will cause the Metal in the water to become visable and actually stain the pool liner and stuff. this is called "falling out of solution". To effectively use this site, I suggest you read through all the different posts that have simmilar problems. you will learn a lot.
Keep posting and people will help. I learned a new acronym last week POP (pool owners patience). I'm now dealing with cloudy water and it is definately testing my POP! Good luck
