Sorry to hear about the flooding! I hope you win!
Just wanted to give an update.
Bonni - if you haven't had any luck try what I just did.
Mbar- Thanks for all you posts it really helped a lot.
This is what I did so far. I went to my HealthFood store and bought 2 (8oz) bottles of Vitamin C (Crystals) (expensive but I was desperate). The Vitamin C will bring down the Chlorine levels fast, and Pool Magnet works at 1pm Chlorine levels. Then I followed some of the instructions that Mbar has posted. Turn the filter off, put the C in and I let it sit for about 1/2 hour. Then I turned the filter back on, added 1 qt of Pool Magnet Plus and let it run overnight. I woke up this morning and it looks like the water is almost back to its Crystal Blue state. Don't know how much impact the rain had but whether it was a little help from God or the Metal Forum Gods it appears I'm on the right track.
The next plan is as follows (would welcome some input).
I expect my pool to get cloudy (due to the pool magnet) I'm going to get a flocking agent and try it. Then I'll vaccum the pool.
I am going to slowly raise my PH to (ok) levels. Then I'm going to slowly (did I say slowly) raise my chlorine levels to the lowest possible (Ok) level. I will be continually adding the maintenance dose of Pool Magnet per week.
Q. I was told by my pool store that they make a non-chlorine shock. Do you think it will react with the metal? Do you have any experience with this?
Do you have any other suggestions for me?
