Thread: Solar Cover Reel Install
    Cleveland, OH
    Default Solar Cover Reel Install
    I am about to install my solar cover reel. I plan to mount the reel on some 4x4s at one end of my pool. I have an AG 24' round pool. Anyone that has done something similar do you have any input on the install?
    1. How high did you mount the reel?
    2. How far from the pool is it?
    3. Any other things you found while installing this?
    Thanks,
    Frank
    csevel is offline Registered+ Thread Analyst csevel 0
    Cleveland, OH
    Default Re: Solar Cover Reel Install
    The poolstore guy told me not to install my solar cover reel on posts as I would only be able to attach two or three straps to the cover for rolling. Is this true? I also didn't want to install the reel in the center of the pool as I would be the only one removing it and I think it might take two people.
    Claudia
    18' Echo Canyon A/G Pool by Artesian
    8500 gallons
    3/4hp Jacuzzi 2-speed pump - Cartridge Filter
    Cleveland, OH
    Quote Originally Posted by csevel
    THere has been several people in this forum that have done it this way. There were pics here before but since the site crash they are gone.
    We have several straps attached to ours - our posts (steel pipes in concrete) are 2.5-3' off the back end of the pool and the reel is set about 1' or a bit less above rail height - my advice, I wish we would have gone higher on the reel height so the blanket would be reeled UP and off instead of straight back and dragging all the way back under the rails. Otherwise, it works awesome. It really gets the blanket off and out of the way, also goes back on just great.
  1. Solar Cover Reel
    By chinewalker in forum Above-Ground Pool Construction & Repair
    Last Post: 08-23-2014, 05:35 PM
  2. Solar Cover Thickness, Reel Quality, Solar Panels
    By vector13 in forum Pool Equipment & Operations
    Last Post: 03-20-2012, 01:45 PM
  3. what is the best Solar Cover Reel
    By Billybob in forum Pool Equipment & Operations
    Last Post: 08-15-2011, 10:43 PM
  4. Solar Cover Reel
    By jrv331 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-13-2007, 02:40 PM
  5. Solar Cover Reel Install
    By MaxxFusion in forum Above-Ground Pool Construction & Repair
    Last Post: 08-01-2007, 02:11 PM
