Results 1 to 1 of 1
Thread: Help with total alkalinity (complicated)
    Question Help with total alkalinity (complicated)
    I have an inground, vinyl liner pool (new liner last year) without a heater.
    I just had my water tested. Everything was OK except the TA measured 180. That's way up over the 80-100 range from last year. I think I know the source. We had to install an acid neutralizer and water softener this year when our well went wonky - the pH dropped to 5.8 and the iron went way up. I topped the pool up with around 6 inches of water that went through the acid neutralizer, but bypassed the softener. I think that put a whole bunch of calcium carbonate into the pool. If I bypass the acid neutralizer and water softener, I will end up with low pH and iron in the pool.
    Now for the questions:
    Should I use water that has gone through both the acid neutralizer and softener (I use a combination of 2 parts potassium chloride to 1 part salt in the softener)?
    Or am I better off bypassing the acid neutralizer (which will lower my ph) but go through the softener to remove the iron?
    If I bypass the acid neutralizer and drop my pH, will adding Borax just add to my TA?
    Will the potassium chloride mess up the pool?
    Thanks.
  1. PH and Total Alkalinity
    By bxb21 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-02-2014, 11:26 PM
  2. Total Alkalinity at 150
    By Chuckles76 in forum Dealing with Alkalinity and Calcium
    Last Post: 06-09-2013, 11:35 AM
  3. Total Alkalinity=0, yes zero!
    By myLABSpool in forum Dealing with Alkalinity and Calcium
    Last Post: 06-03-2012, 01:51 PM
  4. Total alkalinity
    By jksmart in forum Dealing with Alkalinity and Calcium
    Last Post: 07-12-2011, 10:09 PM
  5. Total Alkalinity and Adjusted Total Alkalinity
    By cheshamjim in forum Dealing with Alkalinity and Calcium
    Last Post: 06-18-2006, 09:36 PM
