Results 1 to 4 of 4
Thread: start up question
    Ohio,Canton
    Default start up question
    I have maintained my pool for over 15 year's and never had this problem. In Ohio do to the weather our season didn't start till a week ago. My winter cover is the type that is anchored to the cement walkway. The mesh does allow for fine sediment to filter into the pool. It takes some vacuuming and brushing to clean it up.
    So far I have added 7 gallons of 12% chlorine and I'm still having a problem maintaining the chlorine level . The PH is at 7 to 7.2 and the CYA is really low. I do have a chlorinator that I use tablets as a back up. In all the years I have never had to add more than 3 gallons to start.
    RFE,Ohio 23,000 IG ,DE filter, spa w/cartridge filters
    Ohio,Canton
    Default Re: start up question
    In answer to my own question ,I'm guessing the lack of stabilizer is my problem. I found some stabilizer at menards today (Trihydroxy-s-triazine ) . Is it the same as Cyanuric acid? Will this be ok to use?
    Ohio,Canton
    Again replying to my own thread. Hope this information can help others.
    The CYA in my pool caused the problem. For some reason over the winter the stabilizer went to zero . That had never happened before in all the years I have had the pool. I can't remember having to add stabilizer.
    My primary sanitizer has been liquid chlorine . I use a chlorine feeder with 1" tablets ( trichlor) as a supplement . The stabilizer in the tablets kept the CYA in the water around 50 ppm . When I added the gallons of liquid chlorine at startup ,it did not last long without the stabilizer . As soon as I added cyanuric acid to raise the ppm to 30 ,the chlorine level held. I'm sure there are a lot of pool owners that know all this, I didn't. I hope this can help someone else, thanks for reading.
    Oklahoma city, Oklahoma, USA.
    Where are you getting 12% bleach?
    Kurt Bourn
    24' round 12,000 gal
    Oklahoma City
  1. spring start up question
    By heyjudect in forum --cleanup--
    Last Post: 05-27-2015, 04:00 PM
  2. pre start up heat/ph question
    By not2high2fly in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-03-2012, 07:34 AM
  3. Where do I start...
    By kbrooks in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2011, 10:26 PM
  4. Newbie question - would we be better off to drain and start over?
    By RockheadedMama in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2011, 10:31 AM
  5. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
