Thread: Replacing pump with 2" fittings with one with 1-1/2" fittings and Pentair Rainbow 320
Threaded View
    Apr 2012
    IL, USA
    Default Replacing pump having 2" fittings with one having 1-1/2" fittings/Pentair Rainbow 320
    Hello. I am about to replumb my equipment pad and have two questions:
    1) I have a 35K gallon inground pool with three 1-1/2" intake lines combined into a single 2" pipe which feeds into my single speed, 1.5 hp pump which has 2" input/output ports which runs to my sand filter -> pool heater (also 2" ports for both) then splits into two 1-1/2" return lines. I believe the combined 1-1/2" intake line capacity and the combined 1-1/2" return line capacity allows the 2" plumbing/2" ports in my "equipment domain" to increase overall flow capacity over just having 1-1/2" PVC piping all the way through. Would you agree? However, my current pump is failing so I ordered a Pentair Superflo Variable Speed 1.5 hp pump which I just found out has 1-1/2" input/output ports (with unions that can be 1-1/2" or 2").
    So do the 1-1/2" input/output ports of the new pump now negate any benefits of having 2" PVC pipes in the "equipment domain"?
    2) I am thinking of replacing my current inline chlorinator with a Pentair Rainbow 320 inline chlorinator into my setup. However, the instruction manual states that if you have 2" piping but any of the pump/filter/heater have less than 2" fittings, then a minimum of 6" of 1-1/2" pipe must be installed at the inlet of the chlorinator to achieve enough pressure for proper operation.
    My question is if my pump has 1-1/2" inlet/outlet ports, then will adding a 6" "choke point" of 1-1/2" pipe in the middle of the 2" piping further constrict the flow at all (I suspect not)?
    I only use the inline chlorinator at the beginning of the season to establish a proper CYA level and then switch to manually adding liquid bleach. Or I'll also use it if I'm away for an extended period. If the answer is that the 6" pipe in the middle of the 2" pipe does reduce flow (though I suspect it doesn't), I will consider not adding the inline chlorinator at all and just using floating puck chlorinators for the few times I actually use puck chlorination.
    Thanks for your insights....
  1. How to glue in 12" of pipe and fittings into 9"
    By rocks911 in forum Pool Equipment & Operations
    Last Post: 03-30-2018, 05:13 PM
  2. Pentair Minimax will not fire on and reads "HI"
    By gradynlisa in forum Pool Equipment & Operations
    Last Post: 04-18-2014, 04:38 PM
  3. types of fittings for pump/filter
    By zmanh in forum In-Ground Pool Construction and Repair
    Last Post: 04-11-2014, 01:28 PM
  4. How to modify Intex ABG pool fittings to accept 11/2" pvc pipes?
    By traxx2003 in forum Intex-type Pool Setup & Operations
    Last Post: 06-23-2012, 10:17 AM
  5. Low salt light "ON" on my Pentair SWG
    By mshumack in forum Pool Equipment & Operations
    Last Post: 07-06-2006, 11:52 AM
