Thread: Heldor Pool coping
    Aug 2018
    MA
    Default Heldor Pool coping
    Does anyone know where to buy old Heldor coping?
    I have a ~ 8' piece that needs replacing from tree damage.
    Its from the Cinderella or Cardinal model from Heldor.
    Long shot I know
    Default Re: Heldor Pool coping
    1. There's not currently enough traffic on PoolForum for you to get a NEW answer. But you might take a look at this page: http://cardinalsystemsinc.com/produc...oping-systems/ and see if anything matches up.
    2. Use the Super Search page to create custom Google links that will individually search here, then TroubleFreePool, the PoolSpaForum. Keep in mind, here or elsewhere, an OLD answer can be had quicker than a NEW one. Be wary though: equipment questions like yours sometimes get dodgy answers.
    3. If you don't turn up anything, I'd recommend posting your ? on TFP; they have higher traffic than anyone else. Just keep in mind that enthusiasm and expertise aren't the same thing.
    Upgraded membership and moved thread to the IG pool section. You may need to log out and back in to see everything.
    PS.You can search use Google to search multiple pool sites, using Google's 'advanced search operators" to limit your search to specific sites. This page of mine will create the search links for you. Google knows my site -- and all the others -- much better than those sites internal search functions! And, if you need to post pictures -- of your pool, filter, pump, piping, what-not -- there are instructions on this page
  1. Imperial coping and coping clips
    By Poolsbme in forum --cleanup--
    Last Post: 06-23-2016, 12:47 PM
  2. Pool Coping?
    By mikemorales in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2014, 11:08 PM
  3. Heldor 20x50x 9'6"
    By afulton in forum In-Ground Pool Construction and Repair
    Last Post: 08-12-2013, 11:28 AM
  4. Cement Coping: 2 x 4 Marks in the dried coping: how to remove them?
    By Curlenjik in forum In-Ground Pool Construction and Repair
    Last Post: 01-08-2012, 07:45 PM
  5. Concrete coping vs. rim lock coping
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 08-18-2006, 04:00 PM
