Thread: Switch from BioGuard to BBB with new Intex 18' pool?
    Default Re: Switch from BioGuard to BBB?
    Quote Originally Posted by Arrow7 View Post
    So the big question is.... Can we make our water chemistry adjustments using BBB without starting over - or should we drain and start from scratch?
    You can almost certainly switch without draining.
    As a rule, draining is only necessary if you've used PHMB (Baquacil, Softswim, Revacil, etc) or a copper/silver system. And even then, it's not always necessary so much as just easier, when working with small above ground pools like yours.
    But, you'll almost certainly need the Taylor K-2006 sold by Amazon if you don't already have one. And if you want to 'get it all' now, you'll also eventually need refills for the CYA test: 16 oz bottle of R-0013 and Disposable plastic lab funnels. Try to order from Amazon rather than a 3rd party selling on Amazon: Amazon handles shipping and warranties MUCH better.
    Jul 2018
    Colorado
    Thank you so much!
    And thank you for a great website that tells you so much more than the pool store
    yer welcome . . .
  1. BioGuard balance pak 100
    By jmarty462 in forum -- Subscriber Posts --
    Last Post: 08-28-2014, 02:10 PM
  2. Reviews of Bioguard swimming pool chemicals?
    By Bardo213 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-11-2014, 01:40 PM
  3. Intex Above ground, G.A.M.E Sand Filter, BioGuard Stingy Sticks, and other chemicals
    By kristen in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-17-2011, 04:22 PM
  4. Newbie metal issues - manganese and Bioguard Pool Magnet
    By kearpaul in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2007, 02:28 PM
  5. Bioguard Softswim??
    By yjjeeper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2007, 10:25 PM
