Results 1 to 8 of 8
Thread: Using Sprinkler Pump to fill pool?
    Green Bay, WI
    Default
    We do that every two years with out pool. Fill it from the bay or Green Bay off Lake Michigan. I run it though four 5micron filter to get as much out as I can before it gets in to the pool. Then shock and wait for it all to fall out and vacuum to waste. Works like a charm. The bay water is about 60ppm TDS, while our well water is 1650 TDS.
    I would suggest doing it sooner rather then waiting for everything to start growing in the water. It is also fun to tell people that they are swimming in bay or river water
    Dec 2005
    Royal Palm Beach, Florida, U.S..
    Default
    Thanks for the replies all,I'm definately going this route to fill my pool.
    John
    Honesdale PA
    Default
    If you have a sand filter you can plumb the irrigation pump into the waste line and set the filter to backwash. The water then goes through the filter in the correct direction for filtering and comes out the skimmer. Did this last year when I had to replace about 10,000 gallons from my stream while chasing a leak. Used an old pool pump in the stream. Worked like a champ.
    kaybinster Guest
    Default
    I have a stream on my property that I use to water the lawn. One year I used the irrigation pump to add about 8,000 gallons of water to the pool. Thought it was a great idea, until about 4 days later when the pool was cloudy. It took me about five times changing the DE and adding lots of chlorine to finally get the cloudiness out of the pool. Never ever ever again will I do that.
    Green Bay, WI
    Default
    Yes, I add lots of CL right away on the fill and keep it at shock levels until full to make sure nothing is living in there
    I also put the fill hose right at the bottom intake so it goes right in to the sand filter for some additional filtration right away as well.
    duraleigh Guest
    Default
    Hi, Al,
    While I am completely convinced you are "da' man" for interesting, innovative fixes on pools.......I am racking my brain trying to figure out the advantage in doing this. I know you had a reason and I can usually figure things out but you've stumped me on this one. Help!!
    Dave S.
  1. Easier way to keep pool fill?
    By weifert in forum Pool Equipment & Operations
    Last Post: 05-29-2012, 10:50 PM
  2. Fill with only 1 foot of water and don't fill for 24-48 hours?
    By Jacob99 in forum Above-Ground Pool Construction & Repair
    Last Post: 04-26-2012, 06:00 PM
  3. Have to fill my pool in, what do I use
    By timmie in forum In-Ground Pool Construction and Repair
    Last Post: 04-30-2009, 07:35 PM
  4. Adding sprinkler control to add water
    By beary in forum In-Ground Pool Construction and Repair
    Last Post: 01-28-2007, 08:45 AM
  5. Connecting Pool Fill Line to Sprinkler System
    By joelq in forum In-Ground Pool Construction and Repair
    Last Post: 07-09-2006, 03:19 PM
