Closed Thread
Thread: Softened water
    Jul 2018
    Maryland
    Default Softened water
    A friend asked if starting up her above ground pool with softened water would result in cloudy water. If so, is Calcium Carbonate added as a water "hardener" and if so, to what concentration?
    Thank you,
    Mike
    Default Re: Softened water
    As a matter of long standing policy, we don't do 3rd party discussions. The explanation is long and gory, and doesn't seem to 'satisfy' so I won't bother.
    But have your friend register and post.
    However, briefly:
    + Soft water doesn't cause cloudy water.
    + I'm not sure if you realize what "calcium carbonate" really is . . . but you shouldn't add it to your pool.
    + Ergo, the correct dose is ZERO.
    Thread locked.
Closed Thread
  1. Which water to fill with - softened or reg
    By SoCalBoo in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-26-2006, 07:02 PM
  2. Any requirements for softened water?
    By prh129 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-04-2006, 05:21 PM
