Thread: liner side?
    Default liner side?
    Which way goes toward's the water the smooth side or the textured side?
    Tx
    Yves
    Default Re: liner side?
    It's about 2/3 smooth up and 1/3 textured up, depending on brand. You can always tell by looking at the seams. The side that is up will have nicley trimed seams and the under side will have a much rougher cut. This difference should be day and night.
    Dennis
  1. Should inground vinyl liner be flat against pool side?
    By Janet in forum In-Ground Pool Construction and Repair
    Last Post: 07-21-2012, 09:44 AM
  2. Side Discharge pump
    By penelopepitstop in forum Above-Ground Pool Construction & Repair
    Last Post: 07-13-2007, 11:43 PM
  3. Suction Side Air and leak
    By lcrooks in forum In-Ground Pool Construction and Repair
    Last Post: 05-12-2007, 11:02 PM
  4. suction-side cleaner or pressure-side
    By JShilling in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-08-2006, 07:58 PM
  5. Pressure side cleaners?
    By waterbear in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-07-2006, 03:00 PM
