Results 1 to 10 of 11
Thread: Green Algae
    .San Diego, CA
    Unhappy Green Algae
    This is my first time writing, but I've been reading for the past year since we had our pool put in a year ago. Everyone is so helpful and I have been able to find my answers by reading other's problems. So everyting has been great so far but now I need to know if I'm on the right track or need to drain 1/2 and refill to get my CYA down.
    I have a 7500 gal IG pool, with SWG and solar. Water temp is upper 80's. I regularly only add M. acid and 7oz. of some stuff advised by Gemstone people to keep calcium from forming.
    I have a cartridge filter that was just cleaned after using PhosFree to get my 1,000+ppm phosphates under control. (This was in the beginning of my battle with the algae and what was reccomended by pool store.) Later I read this was not necessary since I still have the algae problem!
    I'm still fighting green algae. Not bad, water is clear, but there are areas where you see it on the walls and my skimmer socks are green when I take them out to clean.
    After much reading I had my water tested at pool store since I don't have a test for CYA:
    FAC .5
    PH 7.8 (before adding 2 cups M. acid)
    TA 60, (I tested it at home at 100)
    CYA 100
    Yesterday, after checking with Ben's Best Guess CYA table, I added 1 1/2 gallons bleach, and then before bed another 1 1/2 gallons. Using the shot glass method I figured my FAC at 27ppm, which with a CYA of 100 I needed it up to 27ppm. Correct?
    I've also just read that it's bad for the TAC to be higher than the FAC. I didn't know that and that has always been the case.
    Now this morning my FAC hasn't gone down so I haven't added anything more but I noticed my skimmer socks are light green again. Does this mean the algae is still alive or just getting filtered out of the water? How do you know when the algae is dead or alive. I will keep an eye on the chlorine and keep it up around 25. How may days?
    Is this the correct battle plan?
    Thanks in advance
    Now this morning
    duraleigh Guest
    Default Re: Green Algae
    Hi, Lynn,
    I assume from "Gemstone" that you do not have a vinyl liner...correct?
    .San Diego, CA
    correct, it a pebble finish
    duraleigh Guest
    Your CYA is very high. I would take the Cl ppm up to 30+ to insure you have reached breakpoint. That will most likely clear the algae from your pool. Be persistent with the high Cl until your water shows no trace of algae.
    FAC(FC) is free chlorine that's good for your pool. CC is combined chloramines that don't do any good but are still there. When you test for TAC (TC), you get the total of FC and CC.
    By shocking your pool, (30+) you will get rid of the CC's and your FC and TC results will be the same number. Your pool will clear up as well.
    I'm assuming you don't have an SWG.
    Your high phosphates may be contributing to your propensity to grow algae...I have no experience and cannot comment on that other than to say high Cl levels are the best preventative.
    Lastly, consider draining 1/2 your pool...maybe twice. That's not too much water and it may give you a fresh start on CYA levels and reduce the phosphates.
    .San Diego, CA
    Thanks,
    yes I do have a SWG. Should I wait to drain 1/2 as a last resort? Will it hurt anything with the chlorine up at 25 to turn off the pump if I drain?
    duraleigh Guest
    Quote Originally Posted by lynn2_cal
    Thanks,
    Hi, Lynn, Yeah, that changes somes things...I should've asked you that first. Yes, drain as a last resort.
    Leave your CYA up there at 100...it's alittle high for SWG, but it'll dilute with rain and refill.
    Still shock the pool as in the earlier post. That'll clear your water, get rid of the CC's and not put a strain on your SWG by asking it to do it. (They're not really good at shocking.....particualrly those high levels.)
    Still can't comment on the phosphates...I have no experience
  1. Replies: 8
    Last Post: 08-04-2012, 10:43 PM
  2. help green algae
    By kchamp in forum Dealing with Algae & Slime
    Last Post: 06-30-2012, 07:14 PM
  3. green algae
    By joecus in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-19-2010, 02:17 PM
  4. Green algae? Mustard algae?
    By AE340B in forum Dealing with Algae & Slime
    Last Post: 07-15-2007, 08:32 PM
  5. Green Algae, now cloudy
    By kjmelak in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-20-2006, 08:25 AM
