Results 1 to 10 of 13
Thread: Intex questions
    Jun 2018
    MA
    Default Re: Intex questions
    Plug the ozone generator . . . it's not doing anything useful.
    I can block off the tube, but what little O3 it might be generating would be left inside the device. Would that be harmful? (like corrosion)
    I am concerned about unplugging the Ozone generator completely, because the machine might throw an error and refuse to work at all.
    I don't know. Try it and see.
    It may just tell you the ozone is unplugged.
    Jun 2018
    MA
    It has a light dedicated to telling you when the O3 generator needs replacing. However, since you say it likely produces so little, I opted for trying to plug the tube. It took me three tries before I found something that worked, but I have finally stopped the bubbles. I have the auto cleaner hooked up now, but unfortunately not much dirt in the pool for it to clean. We'll see how it goes.
    FYI, I have well water. Your comments at the beginning that people should read, say this site can't help you if you have well water. I suggest a small shift in words. I think what you were trying to say is that this site can't help you to solve problems caused by well water, or directly related to well water. Something like that. I am fortunate not to have hard water or iron in my water. However my water is highly acidic. I think our lowest professional testing result came in around 5.5 PH. I think it's gotten lower than that myself. For 14,500 gallons of well water, it took 1 box of soda wash and 2 boxes of borax before the test strips nudged above 6.2. However, they were old strips. It was probably 6.2 before I added the second box of borax. It's now safely above 7.2 after a third box of borax was added. (Yes, I bought new strips, the old ones weren't registering PH or stabilizer correctly)
  1. Semi In Ground Intex 26' Questions
    By QuayM in forum Intex-type Pool Setup & Operations
    Last Post: 05-22-2014, 06:27 PM
  2. New Intex Pool Underlayment Questions
    By rkipper in forum Intex-type Pool Setup & Operations
    Last Post: 04-30-2014, 10:27 PM
  3. General Questions about how to care for my Intex Pool
    By lilchikypoo9225 in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-25-2013, 12:30 PM
  4. Questions on Intex Pool Setup
    By gpurcell in forum Intex-type Pool Setup & Operations
    Last Post: 05-23-2013, 03:03 PM
  5. A few questions for a new Intex 16 X 48 pool
    By NJPaul in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-30-2012, 11:00 AM
