Thread: Back wash
    Barry J is offline Registered+ Thread Analyst Barry J 0
    Default Back wash
    I have an above ground pool with a sand filter, I noticed that when on “filter” setting that there is water coming from the “backwash” valve outlet
    Any suggestions
    Thanks Barry
    May 2014
    Plano, TX
    Default Re: Back wash
    I don't have your answer, but if you post the valve brand and model number, you have a much better chance of getting a useful answer. Posting detailed might help too.
    http://www.poolforum.com/pf2/showthr...oolForum-(2018) tells how to post pics.
    It is a Jacuzzi L190 sand filter , the valve is part number 39-2628-03 7 position dial valve
    May 2014
    Plano, TX
    I'm not familiar with that filter, but here's a link to the manual.
    https://www.psposeidon.com/uploads/l...0123132955.pdf
    Seems to suggest a bad o-ring. Sorry I can't help more, maybe someone else can.
  1. A back wash problems
    By jkiester in forum --cleanup--
    Last Post: 05-23-2017, 10:02 AM
  2. Help Back wash too long
    By kentbracken in forum --cleanup--
    Last Post: 07-14-2016, 10:48 AM
  3. Stuck Back Wash Valve
    By Phillbo in forum Above-Ground Pool Construction & Repair
    Last Post: 01-02-2016, 09:56 PM
  4. Back wash to waste
    By rollinrock in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:16 AM
  5. Back-wash hose busted.
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2007, 01:36 PM
