Thread: Taylor Test kit 2006c
    murtot is offline ** No working email address ** murtot 0
    Saskatchewan, Canada
    Default Taylor Test kit 2006c
    I just got my new test kit and have a question on the relationship between the amount of DPD powder added to a chlorine test sample. The test allows for a 0.2 ppm or a 0.5 ppm titration depending whether the pool water sample is 25 ml or 10 ml. Regardless of the sample size it still indicates to add two scoops of the DPD powder in order to turn the sample pink.
    According to this procedure, the amount of DPD powder added appears to be unrelated to the sample size which, to me, seems intuitively incorrect.
    What am I missing?
    thanks in advance
    106,000 litre inground vinyl with solar
    Default Re: Taylor Test kit 2006c
    it is a tritreation test. DPD is merely the indicator. The titrant will react with the FC in the water (or the CC if you are doint that part) and once the chlorine has reacted with the titrant then it is no longer available to react with the DPD and turn it pink. sometimes half a scoop is all that is needed witha really fresh DPD powder if the chlorine levels are not too high!
    Makes sense.
    thanks
  1. My first test with my new Taylor Kit!!!
    By 392papa in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-18-2012, 08:04 AM
  2. Taylor 2006C test kit mess
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-09-2012, 08:14 PM
  3. Taylor 2006c arrived
    By jeremyweber in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-07-2011, 11:25 AM
  4. Taylor FAS-DPD Test Help
    By buki5 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-15-2010, 11:24 PM
  5. PH test with Taylor 2006k test kit
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-03-2008, 01:19 PM
