Results 1 to 10 of 58
Thread: Upgrade recommendations for replacing 14" Intex sand filter combo?
    May 2014
    Plano, TX
    Default Re: Upgrade recommendations for replacing 14" Intex sand filter combo?
    I found a Hayward pump/filter sizing .pdf that tells how to calculate which pump and filter you need. Based on that document, with a 21" filter, I need a pump that produces between 12 and 44 GPM @ 30' head. According to your suggestion of 12 GPM/sqft - 27 GPM would be the max flow. What would be the minimum flow required to adequately backwash a 21" sand filter - the Hayward S210T in particular?
    15 GPM / sft is accepted. It's what I've designed for on large commercial rehab projects, and always seemed to work OK.
    Generally, a centrifugal pump that will deliver 12 GPM through a filter and return piping is -- under most conditions (obligatory 'weasel' words) -- likely to deliver 15 GPM in a full open backwash.
    May 2014
    Plano, TX
    Doesn't that work out to 36 GPM for a 21" filter - to backwash? And 27 GPM or less to filter? I guestimate that I have about 30' total head restriction in my system. The flow curves in this brochure
    https://hayward-pool-assets.com/asse...f?fromCDN=true
    Show that the SP1750 1/2 hp pump is making about 35 GPM at 30'. That pump might still need throttled to get down to 27 GPM on my system. It also shows that this pump makes about 40 GPM at 25'. Almost exactly what I read the 1 hp pump makes on low. Is 27 GPM enough flow for a manual vacuum head to be effective? I'm certain the 18" filter is plenty big enough for my pool, but it looks like there is no pump small enough to properly operate that filter. It looks like even the 21" filter needs to be throttled on my system - because there is so little piping restriction - to get down to a 12 GPM/sqft flow rate. A one half hp pump would be fine and dandy for a 21" above ground filter system, and Hayward is marketing a 1.5 hp 18" system. Makes me shake my head in confusion.
    You have to look at the flow/head tables. 1/2 HP vs 1.5 HP doesn't necessarily mean ANYTHING, because of all the games they play with horsepower ratings.
    One of the things I've dreamed about, is setting up a pair 'Consumer Reports' type test pools, to test various pumps, valves and filters and then publishing the results. Doing so would provide objective data about that equipment that is not currently available.
    May 2014
    Plano, TX
    Well, one thing is for sure - I now know more than I thought I wanted to about pool filter systems. I can't find much (in some cases - any) flow/head info on AGP pool pumps. I emailed Hayward and asked for that information specifically about the 1 hp 2 speed PowerFlo Matrix. We'll see where that leads.
    At this point, I'm planning on the S210T Pro Series filter and the SP15922S PowerFlo Matrix pump. If I was sure I could still vacuum effectively (with a manual vacum), I'd strongly consider the SP1750 1/2 hp pump. We are leaving for a few days of vacation this month and I'm going to wait till we get back to order.
    I think the system above will clean my pool in about half the time it takes my current system. If I throttle the pump so there's no sand washed out on high, then only use high for backwash and vacuum, this system ought to be a good one. My 14" filter has about 1.06 sq.ft of filter area, the S201T has more than double that. I think I'll be running about the same GPM - if you believe Intex propaganda. I know the Intex system I have blows stuff through the sand.
    Am I kidding my self?
    Power-Flow II flow / head ratings, including SP1750
    Also from https://www.hayward-pool.com/shop/en...ii-a-pppow2--1
    BTW, the KW rating in the first image is nominal, not actual. I can't find actual amps at load for this pump ANYWHERE.
    May 2014
    Plano, TX
    Thanks! Now if I could just get the same info - including low speed - for the PowerFlo SP15922S. I suspect the "Power-Flow II" and "PowerFlo Matrix" tables and charts all have very similar numbers, but I don't know that.
    I'm worried that the SP1750, when the vacuum hose and vacuum head are attached, will not have enough flow to vacuum the pool floor. I don't know how much additional head the vacuum adds and I don't know how much flow is needed for vacuuming. I have this head
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    If the SP15922S on low has performance similar to the SP1750, and it won't vacuum on low, I can turn it on high, then throttle the flow as necessary.
  1. Sand Master Soft Sided Above Ground Pool Sand Filter for 15'x48" Intex Metal Sided
    By ransomedbyfire in forum Pool Equipment & Operations
    Last Post: 07-16-2016, 04:36 AM
  2. wide mouth skimmer/sand filter upgrade
    By kdrennan122 in forum Pool Equipment & Operations
    Last Post: 05-28-2014, 12:30 AM
  3. Using a SuperFlo pump and a 24" sand filter on an Intex pool
    By The Diesel in forum Intex-type Pool Setup & Operations
    Last Post: 05-20-2014, 09:32 PM
  4. Intex combo sand filter SWCG question
    By rmk_racer in forum Intex-type Pool Setup & Operations
    Last Post: 06-15-2012, 11:05 PM
  5. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 01:06 PM
