Results 11 to 14 of 14
Thread: Newbies need help
    Default Re: Newbies need help
    Quote Originally Posted by JJParrish
    Thanks CarlD,
    Will do shot glass as soon as we get the water & will pick up the water hardness stuff. Yep, got the shot glasses.
    1. Are pools supposed to look greenish from a distance above? Ours looks greenish from the house & deck, about 8' above pool-level. But, at pool-level pretty clear, mostly clear w/bluish tint w/slight greenish tint in deep end.
    The water should be clear. The ONLY time a greenish tint is OK is if the liner is green.
    2. Is there a test for algae?
    Green water, patches of algae, elevated CC.
    3. What is the final color supposed to be? Bluish or clear? (We have learned that green is BAD)
    Blue or clear.
    ... (just saw Mel Gibson & bad guy go out 7th floor window into pool that looked green.....this made me question the color thing)
    Again, thanks so much for all your (yall's) help. It's really hot in South Carolina and we sure do wanna' jump in! Thanks, Joyce
    It's hot in north central NJ--100 in my back yard and in the 90's in the shade by the pool, where we are sitting as I write this.....
    Columbia, SC
    Thanks CarlD.
    We think we may have a bluish pool. Here are our #:s:
    FC 3.5
    CC 0
    PH 7.6
    We have been shocking nightly and today, all those #'s held from am to pm. There is no chlorine smell. Do you think we are good to go?
    Of course, we will continue to work on our CYA (test in a few days) and add the calc increaser.
    What do you think?
    Later, and thanks, Joyce.
    If the pool is blue, and you're able to hold the Cl all day, I'd go swimming
    Columbia, SC
    Hi to all.........and thanks to all of you for not only your wisdon, but your willingness to share and be so very nice about it!
    Yep, our pool is blue and the cl & ph are holding steady and we are actually in the pool!..thanks to you folks!
    Next issue:
    On Friday we had our water tested at pool store and we tested - TWICE - before we originally posted our no's.
    The situation is this:
    CYA - zero and Calc Hardness (pool store said 76) our tests (TWICE) said 100. Actually went from violet to blue w/two drops from Walmart 6-way kit. And that is 100 to me.
    At Noon on Sat, since our cya/stab was zero (0), we added appx 2 1/2 lbs cya/stab...trying to lean into 20 or so. Easy going. Pump running.
    At 7 PM Sat, we shocked again w/bleach and ran pump 24 hrs (24 hrs for the cya). Remarkable diff in appearance of water on Sun. Bluish. Lookin' good. ph & cl good and holding all day. cl 4 & ph 7.6 cc 0 (we are starting to do the pool dance about now)
    We got the calc hardness stuff today and BEFORE we added anything, we tested again and after TWO drops of the A stuff, no viloet color. Tried it again, twice. Still, no violet color. So, the question is, where did the water hardness calcum stuff go?
    Well, anyway, we added appx 2 lbs of calc hardness stuff from Home Depot & ran pump for 3 hrs.
    Now I am asking you folks this: where did the calc hardness go? WE have only put liquid bleach, 20 Mule Team Borax & 2+ lbs of CYA in pool. What do you think?
    btw, we are telling Everyone we know w/a pool about this site. Eyebrows raise, and probably so do the hits on your site! Thanking you in advance for your help, and happy swimming, Joyce
  1. It's not just Newbies Who Open To Algae!
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-23-2011, 12:28 AM
  2. Welcome year 2007 agp newbies
    By hrsdennis in forum Above-Ground Pool Construction & Repair
    Last Post: 03-21-2007, 07:03 PM
  3. How Chlorine works.....for newbies
    By duraleigh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2006, 07:52 PM
