Hi, Larry,
I think it depends on YOUR tolerance level. No on else will probably notice it but, if your a little like me, it may nag you endlessly 'til you fix it!!![]()
I'd try to live with it if it's causing you no other problems. I have never patched but can imagine they are quite reliable if done patiently and correctly ( like an owner would do). That said, it is probably not as easy as it may seem.....draining your pool to that level can be a major hassle in itself.
Dave S.
