Thread: Pool is Level but....
    Apr 2014
    Rancho Cordova, California
    Exclamation Pool is Level but....
    I would like to know your opinion or thoughts on how this pool was leveled. See the attached photos after the pool was filled.
    Last edited by sjeffers01; 06-18-2017 at 09:57 PM. Reason: Didn't send attaschmernts
    6.3k gal AG rectangle; Whisperflo 3/4 HP pump WF3; Pentair CCP-240 cartridge; Rainbow #320 Chlorine Feeder; Intermatic Timer; Solar Cover and reel; Taylor K2006 test kit. PF=19
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Pool is Level but....
    Is that a splash pool? If it is, that is an OK way to level. The last picture shows an upright that needs to be adjusted, pool likely stretched outwards and the upright needs to be move out, but there is a tremendous amount of weight on that upright and you will not be able to do it with the pool full.
    Splashpool makes a foot that fits onto the bottom of the bracket, they work well.
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 11:41 AM
  2. Intex Ultraframe 12x24 How Level is Level?
    By DMDPT in forum Intex-type Pool Setup & Operations
    Last Post: 07-29-2012, 02:20 AM
  3. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 10:25 AM
  4. Pool Not Exactly Level
    By davenlu2000 in forum In-Ground Pool Construction and Repair
    Last Post: 09-28-2006, 07:21 AM
  5. water level in pool
    By tara15 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-12-2006, 03:20 PM
