Thread: steps to getting pool chemistry right
    mayfield, ks
    Default steps to getting pool chemistry right
    In what order to adjust these numbers? What are the targets that I'm working towards? My pool is a 25,000 gallon inground, sand filter.
    CyA 30
    PH 6.8 (yellow)
    Alk 20
    CC 2
    16'x36' rectangle 25K gal IG vinyl pool; bleach; Pentair Meteor 26" sand filter; challenger 1 1/2 HP pump; hrs; PS233; rural water ; PF:4.8
    May 2013
    Northwest Indiana
    Default Re: steps to getting pool chemistry right
    You need to raise the ph and get the cc below 1. Not sure about your test kit, but most of the time anything below 7 could be what you read or it could be significantly lower. Use the Best Guess chart and shock your pool until 1) water is clear, 2) cc is 1 or less, AND 3)you don't lose more than 1 ppm of FC overnight. Once that's all stable, you can raise your cya if you want. I always kept my pool around 50 ppm cya. As for alkalinity, that's the last thing to work on. Make sure the others are good first.
    -Eric B. 16x32 rect 14,364 gal AG (Intex Ultra Frame); 14 in sand filter; 1 HP 2800 GPH pump; 8 hrs; Taylor K-2006c, utility water, debris cover
    @Best Guess chart http://pool9.net/cl-cya @K2006 http://pool9.net/testkits
    Jul 2013
    Northern Illinois
    I agree! I would also suggest that you consider using arm and hammer WASHING SODA (about 3 cups to start) to raise both pH and TA and see where you are.
    Did you mean you have a CC reading of 2 or a chlorine reading of 2? How does the water look?
    Jul 2013
    Northern Illinois
    Forgot to add targets:
    CYA: 40-50 depending on how much sun you get
    FC: 5-6 corresponds to above
    TA 50 (alk)
    Anonymous [GDPR] European in the UK Guest
    The TA will change as you raise the pH so wait, The pH will also raise as you add more chlorine so wait also if the pH is stable don't worry about the TA at all with a vinyl liner. I run my pool with a TA of around 30ppm as the pH is very stable at that level.
    What is your calcium hardness?
    So get your chlorine up to shock level to oxidize out the CC, which should be 0 to 0.5ppm
  1. pool chemistry
    By i'm sinking in forum Dealing with Alkalinity and Calcium
    Last Post: 07-24-2013, 03:12 PM
  2. Anyone know pool chemistry?
    By Aggievet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-20-2013, 06:43 PM
  3. Pool chemistry help
    By JenLM in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2011, 11:12 PM
  4. new to pool chemistry
    By mohawk in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 10:26 AM
  5. Pool chemistry
    By jcarroca in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-01-2006, 01:27 PM
