I'm back from the Pool Store - I thought the testing included metals and when I saw it didn't and asked for it, the guy had already dumped my water. He did tell me that the previous owner would have probably mentioned it to me if it had been a problem (but if the previous owner didn't run tests and only used pucks, would he have known? We didn't have a problem until we raised the pH level) and he said it's "not typical" to have problems with metal around here even with well water unless I have copper pipes. (But I live 30 minutes outside the city too)
Here are my other #'s:
Free Chlorine 5.2 ppm
Total Chlorine 5.4 ppm
Combined Chlorine 0.2 ppm
pH OVER 8.2
Hardness 80 ppm
Alkalinity (w/ stabilzer correction) 181 ppm
Cyanuric Acid 130 ppm
Total Dissolved Solids 500 ppm
Recommended adding 1 quart of Super AlgaeBomb 60, said I should see a change in 4 - 6 hours or maybe by tomorrow. He wants me to bring in another water sample Monday and ask it to be tested for metals.
Other notes on the bill:
Add 2 gal and 1 pt of 14 oz Muriatic Acid
Add 45 lb and 5 oz of Water Hardness Increaser
Add 10.0 oz Chlor Shock
He said my Chlorine levels were way too high, needed to be around 1.0 and I was a 5.2. He said we would work on the pH and the Alkalinity Monday, after we see what the Algaecide is going to do.
My question is should I run another sample out there to be tested for metals? Should I add the Algaecide? Add Muriatic Acid ASAP? Where do I go from here? I noticed some white foam in the skimmer today and that's new - is it dying algae?
Robin
25000 gallon in ground pool
Vinyl Liner
Sand Filter
