Results 1 to 8 of 8
Thread: Solar Panel Install
    Honesdale PA
    Default Re: Solar Panel Install
    Mine is a single 4x20 Fafco.
    We mounted 3 of the 2x20s and fed each one rather than in a series. They are mounted 2 high on one side and side by side - 2 up - 2 long. We have a rack about 3' from our pool made of 6 - 2"x52" pvc posts into the ground with concrete with a 45 deg bend up another 52", pvc running across top, chicken wire base and 3 2x4 redwood supports off the top to the ground. The whole thing is about 41' long - the panels "dip" a bit when they lay in the wire but not a lot. Its all plumbed together with pvc and rubber connectors, then flex hose from and to the diverter and to/from the pool. Its all constructed on the north side of our pool, between the pool and some pine trees. Kind of creates a kind of "pergolla" effect behind it with some shade for storage containers, cleaning tools, a thermometer/clock and we put hooks on the bottom of the underwire to hang the leaf rake, pool brush, towels, ect. It was the only place we had to put panels and get sun for heat. You can probably see some of it in our pic posted in the gallery.
    Cleveland, OH
    I installed my panels today. Just laid them on the ground for now but plan to build the rack on Fafco's site. I got the diverte from Fafco with my panels and I had a heck of a time with it. One of the ends kept poping off. I think I am going to go with pvc and cement everything.
    What schedule pipe is recommended and what is your setup if you piped it. I think I am going to stay with the flexible hose from the panels to the pipe. That way it will be easier to store for the winter.
  1. Solar Panel Install: One-Year Update
    By pj1016 in forum Pool Equipment & Operations
    Last Post: 07-17-2007, 01:32 PM
  2. Solar Panel Install w/pcs Part 2 (dial-up beware)
    Last Post: 08-11-2006, 11:10 AM
  3. Solar Panel Install: Part 3 (final post)
    Last Post: 06-21-2006, 04:58 PM
  4. Solar Panel Install w/pics Part 1 (dial-up beware)
    Last Post: 06-20-2006, 08:54 PM
  5. solar panel
    By marchbreak in forum Above-Ground Pool Construction & Repair
    Last Post: 05-03-2006, 08:13 AM
