Results 1 to 4 of 4
Thread: Pentair check valve/divertor
    Mahwah, NJ, USA.
    Default Pentair check valve/divertor
    Does anyone have a suggestion for a temporary solution to stop a damaged check valve/ divertor from leaking? Lost about a foot of water last night checking damaged part (Pentair part # 263042z). Replacement coming from Amazon tomorrow.
    Flap on part was covered in what looked like deteriorating white rubber. Same thing happened a year ago and I'm told this part should last longer. Thanks.
    NJ Pool: In Ground, 40,000 Gal vinyl liner, chlorinated using BBB, Gas Heated, DE Grid filtration.
    FL Pool: 10K gal gunite, chlorinated with 3'' pucks, cartridge filter, spill over spa
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Pentair check valve/divertor
    Sorry no one got to you. Did you get your part? Did you figure out how to stop the check valve?
    Mahwah, NJ, USA.
    I got the replacement part from amazon with expedited shipping and everything is fine again. I could not figure out a temporary fix to prevent the water from draining so had to continually re-fill to prevent the pump from sucking air. I have an infinity edge with auto refill but if the pool gets too low overnight the basin drains faster than the auto fill can replenish. Might purchase a spare valve in a few years to keep on hand, I'd estimate life expectency to be less than 10 years so I have some time to think about it.
    Scottsdale, Arizona
    It's ok to turn your pump off for a couple days if you need too.
    14'x31' kidney 21K gal IG plaster pool; SWCG (Saline Generating System's SGS Breeze); Pentair FNS Plus 48 DE DE filter; Whisperflow 1 HP pump; 8 hours hrs; kit purchased from Ben; utility water; summer: none; winter: none; PF:5.7
  1. where should a check valve be installed
    By poolfix in forum --cleanup--
    Last Post: 06-20-2016, 09:19 AM
  2. Check Valve Help!
    By TazJMT in forum Pool Equipment & Operations
    Last Post: 06-23-2014, 09:08 PM
  3. Check valve question
    By Rockman59 in forum Pool Equipment & Operations
    Last Post: 06-19-2014, 01:56 PM
  4. Rattling Check Valve
    By nomar116 in forum Pool Equipment & Operations
    Last Post: 04-07-2013, 06:58 PM
  5. Check Valve
    By jrv331 in forum Pool Equipment & Operations
    Last Post: 05-30-2006, 08:39 AM
