Results 1 to 8 of 8
Thread: What kind of eyeball return jet is this?
    Default What kind of eyeball return jet is this?
    I need to replace some broken eyeball return jets in my pool, but I'm confused about one of them as it's not a regular threaded eyeball, but it's longer and seems to be either threaded or pushed into the pool wall. I can turn it, but it turns the whole thing, not only the eyeball nut itself since it's not threaded there.
    Any help on what kind it is and how to go about replacing it would be appreciated.
    Jul 2013
    Northern Illinois
    Default Re: What kind of eyeball return jet is this?
    Could it be a push-in slip/fit type? Check these out:
    http://www.poolcenter.com/search?Ntt...20in%20eyeball
    If so, this looks to be the current best price:
    http://www.ebay.com/itm/like/1611575...&ul_noapp=true
    Thanks for the info!
    I'm going to swing by the local pool store and show them the picture as well. I'll post back once I know for sure.
    Jul 2013
    Northern Illinois
    Great! Let us know, and good luck.
    Last edited by FormerBromineUser; 03-13-2017 at 01:03 PM. Reason: Copied wrong message.
    Yes, you were right. It simply took a little elbow grease to get it out. I tried 2 replacement ones and neither fit snugly but I'll make it work.
    Thanks!
    Jul 2013
    Northern Illinois
    The one below has a "bulge" on the stem that might help. I don't like the eyeball, but it looks like you might be able to swap it out for a standard one. Maybe it's worth a call to see if they have other "bulged" ones.
    http://www.swimcsi.com/55-276-1020.h...kw=55-276-1020
  1. Return eyeball has a funnel
    By Bonnie25 in forum Pool Equipment & Operations
    Last Post: 07-20-2012, 09:01 PM
  2. Return water eyeball
    By Bekka in forum Pool Equipment & Operations
    Last Post: 05-31-2007, 02:50 PM
  3. Eyeball return direction???
    By pool newby in forum Above-Ground Pool Construction & Repair
    Last Post: 07-26-2006, 06:56 PM
  4. Connect regular PVC fittings to eyeball return in pool?
    By aquarium in forum Pool Equipment & Operations
    Last Post: 07-07-2006, 05:10 PM
  5. Hayward eyeball return connection- Long
    By EricF in forum Pool Equipment & Operations
    Last Post: 05-26-2006, 12:30 PM
