Thread: salt ppm on SWCG readout is on the rise
    Jun 2013
    Default salt ppm on SWCG readout is on the rise
    What can cause the reading on the system to rise. We got the system at the start of this season. Had to have the first one replaced after 2 months because something shorted in it. This one has been in place since the first of July. It stayed at 3200 ppm readout almost the entire time we have had it. I have added no salt. Two days ago the reading shot up to 3400 ppm and today it is up to 3600 ppm without my adding any salt. They told me to keep it between 2700 to 3400. It is producing chlorine though.
    Free Chlorine 2
    PH 7.6
    Alkalinity 100
    PF=5; 23K gal IG kidney vinyl pool, Triton II Sand Filter, Whisperflow VS Pump, Taylor 2006 kit, Jacuzzi/Carvin Saniclear 40 SWCG
    Scottsdale, Arizona
    Default Re: salt ppm on SWCG readout is on the rise
    I would suspect a faulty read out if you are not adding salt.
    mas985's Avatar
    Pleasanton, CA
    Some SWGs don't compensate the salt readout for water temperature very well so if your water temperature went up recently, that could account for the change.
    But don't worry too much about the salt level that it reads. Only be concerned if the unit alarms or shuts off because of it.
    Mark
    Jun 2013
    Good to know, but how will I know if the salt level is good? I have just been checking the chlorine, ph, and alkalinity levels and relying on the system to give me the salt ppm. I just bought some salt test strips...thought I would try that too.
    Thank You.
    mas985's Avatar
    Pleasanton, CA
    The only thing that matters is that the SWG unit is happy (i.e. no alarms). It doesn't matter what the true salt level is only that the SWG unit thinks it has the correct salt.
    Mark
  1. Adding salt without a SWCG
    By jjl64 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-03-2014, 10:20 PM
  2. Minimizing pH rise in SWCG pools
    By Watermom in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-13-2012, 11:55 PM
  3. Is my salt level too high? Test vs. digital readout.
    By Furbabyvet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-24-2011, 03:35 PM
  4. PoolPilot Total Digital ORP readout
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-09-2008, 10:38 AM
