A 14 inch piece of pvc pipe was inadvertently sucked down one of the skimmer tubes (there are 2 skimmers in the pool). The dropped pvc pipe was only slightly less in diameter than the skimmer tube itself. The skimmer tube goes down about 6 or 7 feet, and then there is an elbow. I imagine that is where the dropped pvc pipe is, nesting inside the skimmer tube, on pipe inside another, however I cannot see it. The suction doesn't seem to be affected, at least not yet. I guess that is because the dropped object is a pipe so the water just flows through it. I have now turned the pump off. I worry that it will somehow block the pipe running into the skimmer tube horizontally at the elbow. The edge of the dropped pipe is likely almost flush against the skimmer tube. How can I get this dropped piece of PVC pipe out?
