Thread: Automatic Pool Cover closing issue
    Apr 2012
    St. Louis metro area
    Default Automatic Pool Cover closing issue
    We have an Automatic Pool Cover installed on our pool. When I turned the key switch tonight to close the cover, a solid red light came on the key switch box. I reset the breaker and it worked for about 5 seconds. I had to continually go through this process approx a dozen times in order to get the cover closed. Anyone have any idea what might be causing that? I can't find anything in the manual or on their website. Thanks.
    11,700 gallon Leisure Elegance 27 fiberglass pool, Pentair Intelliflo pump, IntelliChlor IC20 ECG, UltraTemp heat pump, IntelliBrite 5g LED light, EasyTouch 4, DeckJet II, Automatic Pool Covers AutoGuard Top Track
    Apr 2012
    Default Re: Automatic Pool Cover closing issue
    Update: Pool company came out to check into our issue. They believe that it's either a sensor or the cover motor. This was installed in 2012, so the motor is only 4 years old. Hopefully it's only a sensor, because I really don't want to drop $1200 on a new motor! Will update with more info once they can pinpoint the problem.
    Virginia
    Yikes! Pricy motor!
    Jul 2013
    Northern Illinois
    Yea, they are expensive. Mine is over 10 years old and will need replacing soon. Saving up! I hope your warranty covers at least part of it!
  1. Winter closing IG BBB Safety Cover - Best Chemical Balance prior to closing?
    By blue wolverine in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 08-16-2012, 04:36 PM
  2. Automatic pool cover?
    By awhite6455 in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2012, 08:07 PM
  3. Automatic Pool Cover Switch
    By tmassengale in forum Pool Equipment & Operations
    Last Post: 06-04-2012, 10:15 PM
  4. Automatic Pool Cover problem
    By buki5 in forum Pool Equipment & Operations
    Last Post: 04-08-2011, 09:27 PM
  5. Automatic Pool Cover - Which One - HELP!
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-31-2006, 12:09 AM
