Thread: Shutting Pump Off & Covering For Vacation. Tips?
    swimdaddy is offline *Removed User* Weir Watcher swimdaddy 0
    May 2014
    Washington state, east
    Default Re: Shutting Pump Off & Covering For Vacation. Tips?
    If you are not able to run the pump for 8 days, and you are already struggling with algae and getting pool chems right (pH is low, CYA is high), chances are you will have more problems when you get back.
    1. Get your pH up to mid 7's, that way if it fluctuates a little while you are gone you good.
    2. Use some polyquat algaecide to clear your pool, with your pool I wouldn't use more than 2-3 ounces
    3. Polyquat will drop your FC, so then get your chlorine levels up to shock levels.
    I don't know why you can't run your pump, and you don't really need to close your pool.
    Oct 2011
    Southern New Jersey
    Thanks swimdaddy! It has not been a good summer so far (look at my recent posts!!!) My pump is also having issues and I don't trust it running 8 days unsupervised. I've also had a windy storm blow leaves / twigs / debris into pool and if that happens while away the skimmer would definitely fill and then low flow into pump equals disaster! Will take my chances with the chemistry and possibly get new pump upon return. As for polyquat, how/when do I dispense? 1 day prior to shut down and allow to filter or after shut down across still water? Thanks!
    Steve Romo (6700g AG, Cartridge Filter)
    May 2014
    I would use polyquat 1 or 2 days before because you chlorine will drop, so you need to give yourself time for that to happen and then bring chlorine back up to shock levels, which with a CYA of 100 is going to be around 25 ppm. For your pool, that would be around 2 bottles of 8.25% bleach to raise from 0 to 24 ppm (doing math in my head, correct me if I'm wrong).
    Oct 2011
    Southern New Jersey
    Back from trip, no problems to report!! Added 3oz of Poly 3 days prior, shocked 1 day prior. Shut pump and covered for 8 days. Removed cover with no water issues upon return. Thanks for the tips!!
    Jul 2013
    Northern Illinois
    Yay! Good job, Swimdaddy and steveromo!
    Virginia
    Sweet!
  1. Tips on deciding to replace pump?
    By Whetstone613 in forum Pool Equipment & Operations
    Last Post: 07-23-2014, 08:35 PM
  2. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 08:32 AM
  3. Piping filter/pump/heater. Any tips?
    By cruzmisl in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2007, 10:52 AM
  4. Protecting/Covering a Pump/Filter during use
    By NWMNMom in forum Above-Ground Pool Construction & Repair
    Last Post: 06-08-2006, 04:25 PM
  5. Pump won't run after shutting it off.
    By hoogie in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 10:08 AM
